URL redirect
Thread began 4/19/2010 3:57 am by gwh362692 | Last modified 9/09/2011 11:57 am by Ray Borduin | 2504 views | 7 replies |
gwh362692
URL redirect
Hi everyone,
I have a page on my site with a series of links that, when clicked, submit to a page (index.php) located in the same directory as itself, eg.
<li id="formal"><?php echo "<a href=\"$url_consumer/index.php?subcatID=6&itemTypeID=1\">Link 1</a>"?></li>
index.php contains only php and basically just queries a database and then loads the information into the current page with the links in it.
This page with all the links in it, also contains a form which when submitted, inserts the information into a database table and is then redirected to the current page:
$WA_redirectURL = "?sent=true";
On this current page, the first 'confirm' paragraph below is supposed to be shown:
<?php if(isset($_GET['sent']) && $_GET['sent'] == "true") { ?> <p id="confirm" style="background-color: #ded5b3; color: #00274c; padding: 5px; margin-bottom: 8px;"> <strong>Thank you – your details have been processed. </strong></p><?php } else { ?>
<p>Subscribe to our newsletter.</p>
<?php } ?>
It doesn't seem to work though because even though it's submitting to itself, it's not loading the current page because it needs certain information in the url string to do this (see the abovementioned link). When the submit button is pressed the following is at the end of the url:
index.php?sent=true
Since index.php is the php page that only queries the database the page shown is blank and not the page that was previously seen, before submitting the form.
I just wondered if anyone knows of a workaround for this problem?
Appreciate any advice.
so basically your page is relying on the subcatID=6&itemTypeID=1 query string variables?
you can add those into the redirect so they are passed when the page is redirected:
$WA_redirectURL = "?sent=true".((isset($_GET['subcatID']))?"&subcatID=".$_GET['subcatID']:"")."".((isset($_GET['itemTypeID']))?"&itemTypeID=".$_GET['itemTypeID']:"")."";
gwh362692
That's great - thanks very much.
Just a related question if that's ok: as mentioned I have this form on each of the pages of the site that allows users to sign up for a newsletter. The following shows one of the input fields in the form:
<div>
<input id="firstname" name="firstname" type="text" value="First name" onfocus="if (this.value == 'First name') this.value=''" onblur="if (this.value == '') this.value='First name'" />
if (ValidatedField('index_965','index_965')) {
if ((strpos((",".ValidatedField("index_965","index_965").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span style="color: red; margin: 0; padding: 0;"> First name is required </span>
<?php //WAFV_Conditional index.php index_965(1:)
</div>
I used a Data Assist insert server behaviour to insert the contents of the form into a DB table. The following is the code produced by the server behaviour:
<?php require_once("/home/site/private/newsletter.php"); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (isset($_POST["submit"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_index_965_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST['firstname']) && $_POST['firstname'] != "First Name")?$_POST['firstname']:"") . "",false,1);
$WAFV_Errors .= WAValidateRQ(((isset($_POST['lastname']) && $_POST['lastname'] != "Last Name")?$_POST['lastname']:"") . "",false,2);
$WAFV_Errors .= WAValidateEM(((isset($_POST["email"]))?$_POST["email"]:"") . "",true,3);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"index_965");
// WA Application Builder Insert
if (isset($_POST["submit"])) // Trigger
$WA_connection = $newsletter;
$WA_table = "subscriptions";
$WA_sessionName = "subscriptions_subID";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "subID";
$WA_fieldNamesStr = "firstname|lastname|email";
$WA_fieldValuesStr = "".((isset($_POST["firstname"]))?$_POST["firstname"]:"") ."" . "|" . "".((isset($_POST["lastname"]))?$_POST["lastname"]:"") ."" . "|" . "".((isset($_POST["email"]))?$_POST["email"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''";
$WA_connectionDB = $database_newsletter;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
Since the newsletter form is potentially open to a sql injection, I wondered if the code produced by the server behaviour contained any protection against this security risk. As I don't understand a lot of the code produced, could you tell me if it has taken care of it or whether this is something extra I need to add to the input fields?
DataAssist does include code to help prevent SQL Injection attacks. using form validation is also a good idea.
In your form validation, you should be validating the data types for the different fields. For example, I see you have applied Email Validation to the email address form field, but only Required Validation to the First name and last name fields.
It would be a good idea to use alpha numeric validation on those fields instead to restrict special characters from being entered.
validating on the data type can help further prevent against SQL Injections.
gwh362692
Ok thanks for the information.
Web Designer Troy
Data Injection Hack
I was hacked (sql injection) through address bar using the dataassist app. Is there any protection on a level where I can't validate. Please help.
We looked into this problem over the phone. It is not an issue with our software.
The injection hole was due to having built the recordsets with DW8. We solved it by opening up the recordset SB and reapplying.
