Theme-it ... Error
I just bought and installed Theme-It. When i try and open it I get this java error message "wa_themeit.js" (see attachment below)
I read through the other threads but can't seem to find a fix.
Please help.
Thank you,
Bill
Please help.
Thank you,
Bill
Hi all,
The majority of javascript errors that occur when using extensions is because of a cache file in dreamweaver that gets corrupt and messes everything up. The solution is to delete this file and restart dreamweaver and then everything should go according to plan.
See here for instructions: 146/
Many of have been told that Adobe has addressed this issue and it won't be a problem any longer in dreamweaver cs5 (fingers crossed).
Regards,
Brian
I tried that and still cant get it to work.
can you send a copy of the page you are trying to use them-it on? Please include all supporting files especially css so I can try to reproduce the error to find the cause.
