Step 1 installation - file permissions
Thread began 4/16/2010 1:44 pm by director404444 | Last modified 7/02/2010 9:04 am by Justin Nemeth | 1535 views | 3 replies |
director404444
Error message says "Files and directories cannot be created. Verify your powergallery directory has write permissions."
How do I authorize write permissions to continue with Installation process?
Jean-François
Justin Nemeth
Using your ftp software, you can give write permissions to the main powergallery directory. Usually you just right click on the remote folder and choose change permissions and it will popup a box allowing you to give write permissions. Alternately, you can use your web hosts control panel to allow give the correct permissions to the directory.
-justin
mjlowery2010409736
Re:
I was having the same issue with the file permissions. I am using godaddy.com as my hosting provider. I went into my file manager tab and located all of the files of the PowerStore. Using the godaddy built-in FTP client I changed the file permissions of the directories and sub-directories of all the files. I am still seeing the error in the installation wizard about the file permissions. I have also updated the 5 files found in a download:
# install/2.php
# install/scripts/db.sql
# Admin/Update_ProductCoupons.php
# Admin/Products_Results.php
# WA_DataAssist /WA_AppBuilder_PHP.php
Am I still doing something wrong here? Please help me out
-Mike
Justin Nemeth
You need to change the permissions for the main directory you uploaded the files to, not the sub files or folders. The install wizard creates some new directories and files automatically, so that is why the main directory needs the permissions.
