Dropdown list resetting to default - Dataassist
Thread began 4/15/2010 4:18 pm by fabianmacs370894 | Last modified 4/16/2010 12:15 pm by fabianmacs370894 | 763 views | 2 replies |
fabianmacs370894
I have created a DB with a dropdown list that populates a record. Problem is it works perfect when there are just 50 characters, but when any more than 50 are added it resets the dropdown list to the default of 'select' after I perform an update, then goto results, then detail page. any solutions why this might happen?
Fabian
eaf-database-site 2.zip
in your events table, the category_eng column is set as a varchar column with a maximum length of 50 characters.
In the category_tbl table, the category_type column is set to be a text column which can hold thousands of characters.
fabianmacs370894
Jason,
That worked perfect - I overlooked the character length in that table.
Thanks for help.
F
