Upload Error
Thread began 4/14/2010 10:43 pm by windsoarer388279 | Last modified 4/16/2010 11:47 am by Jason Byrnes | 589 views | 3 replies |
windsoarer388279
Upload Error
I'm getting the session_start error in my image upload page. The file and record both get uploaded fine, but when the upload completes the error is on the top of my page. Attached is my file, any help is appreciated.
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home3/aginsign/***/upload_new.php:1) in /home3/aginsign/***/webassist/file_manipulation/helperphp.php on line 58
upload.zip
change lines 1 - 3:
<?php virtual('/Connections/connAgin.php'); ?>
<?php virtual
("/WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php virtual
("/webassist/file_manipulation/helperphp.php"); ?>
<?php require_once('Connections/connAgin.php'); ?>
require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
require_once("webassist/file_manipulation/helperphp.php"); ?>
Dreamweaver will use the virtual syntax if you set the "Create Links Relative To" option on the Local Info tab of your site definition to Site. the virtual syntax will cause the headers already sent error. Set that to Document instead so that Dreamweaver will use the require_once syntax.
windsoarer388279
Yes that was easy. Just realized that change was made since I reloaded Windows and re-setup my site.
Thank you very much.
you're welcome.
