level 2 being overlayed by level 1
Level 2 being overlayed by level 1. Here is the problem.
CopynavbarAdm.asp
how to fix?
TIA.
CopynavbarAdm.asp
how to fix?
TIA.
You will need to adjust the left margin on the Level 2 items. Edit the theme and select the box tab, then select level 2. In the area below adjust the margin, but only set the left margin. When I set it to 20px it seemed to work out ok.
Thx much Eric!
Easy problem with easy solution.
Always happy to hear when things work out, let us know if you have any further questions about any part of this or if you encounter any issues.
