Copy site and database schema to another
Thread began 4/14/2010 7:45 am by mr hankey | Last modified 4/15/2010 11:06 am by mr hankey | 1297 views | 4 replies |
mr hankey
I was wondering if anyone at WA or within the community have ever done this before.
Basically I have my site setup within dreamweaver connecting to my remote myssql database.
I want to use all the same layout of the site all the pages i have generated with WA extensions and take an sql dump file and create a new database in phpmyadmin and have the site connect to it?
not sure if i am explaining this properly.
I have just now say companyname.com which connects to mysql database called database1
i want to copy all the site files exactly the same as the above with a new database but same setup with tables so the pages i created with webassist extesions work.
so the new site would be say subdomain.companyname.com with database = database2
how easy is it to copy all this in dreamweaver so that the files all link to the new database?
is it a case of copying alll to the new site folder on web host and changing the includes connection file to the new database details?
or do i copy it to a new folde rlocally on my machine, open up one of the pages and create a new site and database connection and will dreamweaver automatically update all the connections to the new database?
hope someone can help,
many thanks
Jimmy Wu
If you update the connections file and upload the files to the correct place, with the correct directory structure, then it should connect correctly. Make sure you make a backup copy of your working site before making any edits first.
mr hankey
thanks jimmy, so only the connections folder needs modified? all the recordsets etc will work?
have you or anyone else done this before?
many thanks
Jimmy Wu
Yes, that should be the only thing you have to change. The pages should be created as relative links, so they're not site specific. I have set up a site on a local testing server and deployed it on a live server before, but I didn't change the database connection since it still connected to the same database server. As long as the connection is still called the same, the pages should still use it.
mr hankey
thanks jimmy
