Email issues and PEAR
Thread began 4/10/2010 2:43 pm by paul.urgero235355 | Last modified 4/23/2010 2:26 pm by Eric Mittman | 1448 views | 9 replies |
Paul
I'm having great difficulty configuring PS2 to send Verification Emails. While reading the posts in the forums, I read about using PEAR, which is installed on our server at: C:\PHP\PEAR
So in the User_Registration.php file, I configured Universal Email to use PEAR MAIL using SMTP, with the following settings:
Authenticate is checked
Email address and password are entered
Path to pear: C:\PHP\PEAR
SMTP server: 192.168.1.11
Port: 25
I've gone into the WAUE_users_Registration_1.php file, and changed line 15 to:
$WA_MailObject = WAUE_Definition("".($WAGLOBAL_Email_Server) ."","25","xxxxxxxx","xxxxxxxxx","True","","","","");
When I try and register an email address (whether one that is hosted on the same server or not), I get:
PHP Warning: require_once(192.168.1.11Mail.php) [function.require-once]: failed to open stream: No such file or directory in C:\Inetpub\wwwroot\hcprivate\AcalaMed\acalamedical.com\www\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115 PHP Fatal error: require_once() [function.require]: Failed opening required '192.168.1.11Mail.php' (include_path='.;C:\php5\pear') in C:\Inetpub\wwwroot\hcprivate\AcalaMed\acalamedical.com\www\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115
Line 115: require_once($mailObj->PearPath."Mail.php");
In my global settings, I've changed the mail server from "" to localhost, to 192.168.1.11.
I've tried changing the Mail.php to: C:\PHP\PEAR, no change.
One thing I can't understand, is the phpinfo test page shows: include_path .;C:\php5\pear but that path doesn't exist on the server, or in the php.ini file.
I am completely at a loss, and would appreciate any help, or for support to open up an immediate ticket.
Thanks,
Paul
It looks like the paths are just not working out correctly. The first thing you should do is check what value the Pear Path is set to just before the line that gives you an error. It seems that the path is not getting to this area the same as you are entering it.
To check on this put in this code just before the error line 15:
die("the pear path value is: " . $mailObj->PearPath);
This should stop execution and print out the message with the value for you. Let us know what it comes back with, also, post back with a copy of your page that has the UE on it and your UE folder from the site, I might help to have this code around as well.
Paul
Hi Eric,
The answer came back as: 192.168.1.11
Thanks for your help.
Paul
WA_Universal_Email.zip
users_Registration.zip
I have done some searching into this issue and I think I might have found out the problem. It looks like the first parameter you are passing into the WAUE_Definition is not correct. The first parameter in this function call should be the path to the PEAR object, instead you are passing it the server value.
It should look something like this:
WAUE_Definition("C:\\php\\PEAR\\","".($WAGLOBAL_Email_Server) ."","25","xxxxxxxx","xxxxxxxxx","True","","","","" );
Please update this and test it out, let us know if it does not resolve the problem. You will need to remove the debug code that you added to the file.
Paul
Hi Eric,
No luck:
PHP Warning: require_once() [function.require-once]: open_basedir restriction in effect. File(C:\php\PEAR\Mail.php) is not within the allowed path(s): (C:\Inetpub\wwwroot\hcprivate\AcalaMed\acalamedical.com) in C:\Inetpub\wwwroot\hcprivate\AcalaMed\acalamedical.com\www\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115 PHP Warning: require_once(C:\php\PEAR\Mail.php) [function.require-once]: failed to open stream: Operation not permitted in C:\Inetpub\wwwroot\hcprivate\AcalaMed\acalamedical.com\www\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115 PHP Fatal error: require_once() [function.require]: Failed opening required 'C:\php\PEAR\Mail.php' (include_path='.;C:\PHP\pear') in C:\Inetpub\wwwroot\hcprivate\AcalaMed\acalamedical.com\www\webassist\email\PEAR_Mail_using_SMTP_php.php on line 115
Here's line 115: require_once($mailObj->PearPath."Mail.php");
Thoughts?
Appreciate the help!
Paul
It looks like you have made the update correctly. The errors here are telling you that the open base dir directive is in effect. When this is set you can only include files that are within the specified path. In order to use include files you will either need to move all included files into the directory specified and update the paths or turn this restriction off. It would be much easier to turn this off. Depending on how it is set either directly in the ini or with safe mode being on you may need to contact your host to alter this setting.
Paul
Eric,
I'm getting the same results. Whether open base dir is enabled or not, with the full path or not. Can someone open a ticket and contact me quickly? I'm running out of time.
I have full access to the server.
Paul
I opened a ticket for you on this. Please respond to the ticket in your support history, I have request the full current error message you are getting after you have turned the open base dir off.
Paul
This posting is a continuation of another. Sorry for double-posting, but the other one was to get some view points.
But, as I mentioned to Eric in my support ticket, this issue has been fixed. And I am also not afraid to admit when user error rears its ugly head.
One of the test sites that I've created on my server is successfully sending verification emails. All these files are in their raw, unedited stage (except for the database and Connections files obviously). So this told me that it works on my server.
Somewhere through all the customizations, I must have changed one of the files somehow, in the WA_Universal_Email folder. I replaced the folder, and the users_Registration.php file, with the original files from the zipped PS2 download...uploaded them to my server, and successfully received the emails.
So the moral of the story is, if all else fails, replace the edited files with their originals.
Thanks for your help, Eric.
I'm very glad to hear that. Did you ever get that test email script to work?
