Passing Session Vars to Next Page...
Thread began 4/09/2010 10:40 am by iamdan356160 | Last modified 4/10/2010 7:59 am by iamdan356160 | 877 views | 5 replies |
iamdan356160
I've created an insert form using DataAssist, which is working fine... But I want to be able to pull up the details that are submitted to the database, on the next page.
So this is the code that has been generated for the insert page...
<?php require_once("../Connections/EBP_con.php"); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $EBP_con;
$WA_table = "UserDetails";
$WA_sessionName = "WADA_Insert_UserDetails";
$WA_redirectURL = "autolist.php";
$WA_keepQueryString = false;
$WA_indexField = "UserID";
$WA_fieldNamesStr = "FirstName|SecondName|Tel|Email|Username|Password";
$WA_fieldValuesStr = "".((isset($_POST["FirstName"]))?$_POST["FirstName"]:"") ."" . "|" . "".((isset($_POST["SecondName"]))?$_POST["SecondName"]:"") ."" . "|" . "".((isset($_POST["Tel"]))?$_POST["Tel"]:"") ."" . "|" . "".((isset($_POST["Email"]))?$_POST["Email"]:"") ."" . "|" . "".((isset($_POST["Username"]))?$_POST["Username"]:"") ."" . "|" . "".((isset($_POST["Password"]))?$_POST["Password"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_EBP_con;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<head>
<title>Product Registration</title>
<meta http-equiv="Content-language" content="en-GB"/>
<meta name="rating" content="General"/>
<meta name="revisit-after" content="1 days"/>
<meta name="ROBOTS" content="ALL"/>
<meta name="keywords" content="" />
<meta name="description" content="" />
<link href="/styles/global.css" rel="stylesheet" type="text/css" />
<link href="../WA_SecurityAssist/styles/Traditional_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="../WA_SecurityAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div class="WADAInsertContainer">
<form action="Registration2.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<table class="WADADataTable" cellpadding="3" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">FirstName:</th>
<td class="WADADataTableCell"><input type="text" name="FirstName" id="FirstName" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">SecondName:</th>
<td class="WADADataTableCell"><input type="text" name="SecondName" id="SecondName" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Tel:</th>
<td class="WADADataTableCell"><input type="text" name="Tel" id="Tel" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Email:</th>
<td class="WADADataTableCell"><input type="text" name="Email" id="Email" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Username:</th>
<td class="WADADataTableCell"><input type="text" name="Username" id="Username" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">Password:</th>
<td class="WADADataTableCell"><input type="password" name="Password" id="Password" value="" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="../WA_DataAssist/images/Pacifica/Elemental_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="UserDetails_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../WA_DataAssist/images/Pacifica/Elemental_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
</body>
</html>
And this is the code I've generated for the next page...
<?php require_once('../Connections/EBP_con.php'); ?>
$colname_Recordset1 = "-1";
if (isset($_SESSION['mysql_insert_id'])) {
$colname_Recordset1 = (get_magic_quotes_gpc()) ? $_SESSION['mysql_insert_id'] : addslashes($_SESSION['mysql_insert_id']);
mysql_select_db($database_EBP_con, $EBP_con);
$query_Recordset1 = sprintf("SELECT * FROM UserDetails WHERE UserID = %s", $colname_Recordset1);
$Recordset1 = mysql_query($query_Recordset1, $EBP_con) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
</head>
<body>
<?php echo $row_Recordset1['FirstName']; ?><?php echo $row_Recordset1['SecondName']; ?> (
<?php echo $row_Recordset1['Email']; ?>) test6
</body>
</html>
mysql_free_result($Recordset1);
As you can see, I'm expecting to see the name, second name and email address, after submitting the form! But it doesnt seem to work! Any ideas?
Thanks in Advance!
the insert is storing the ID in a session named "WADA_Insert_UserDetails":
On the detail page, you should be filtering the recordset using the WADA_Insert_UserDetails session variable, not the mysql_insert_id session variable.
iamdan356160
Thanks for the quick responce... But i tried that... and just tried it again! but still did'nt work im afraid!
try adding the following code at line 1 of the detail page:
<?php if(!session_id()) session_start(); ?>
iamdan356160
How I seem to be getting this error...
' Duplicate entry '' for key 1 '
Any ideas?
iamdan356160
Ignore that last post!!
I thought I'd given the primary key property (auto Incremetal = true)...
But it hadn't seemed to have taken effect! Done it now!! and that last snippet
of code to add to line 1 did the trick!
Cheers ever so much!!
