Removing Grey Background on Grid+Lightbox
How do i remove the grey background on the grid and lightbox, i have tried editing the common.css with no success??
Clinton
Clinton
depending on whether you are using the light or dark Grid + Lightbox design, you will need to edit the light.css or dark.css file.
the gray background is set in the pg-gl class:
.pg-gl {
background-color: #1e1e1e;
