CS Form Builder "WAFB_Addform"
Hello,
I can't use Insert form in CS Form Builder.
Message :
When running in the onload WAFB_Addform.html, JavaScript errors:
WAFB_Addform initilizeUI is not defined
Cordialy.
Hello,
Message :
Cordialy.
Try following the steps in the common installation issues document:
Thanks Jimmy Wu for the following.
technote...ion_issues.pdf
Did that work for you? If it did, that's great to hear. If you run into other issues please feel free to open a new thread.
Thanks Jimmy for your help.
The CSS form Builder is OK now.
I have another problem when i open dreamweaver,
I have this message "Wa_xml editor.htm Is Not in Configuration / Floaters"
And the range of processing does not work in WebAssist Site Tools.
Ny France.
