Map does not show
Hi, I am using the test key in Dreamweaver 8. When I hit F12 to view a test I get the goole grey box where the map should be but the actual map does not dispay.
Have attach an example.
can you send a link where i could see the problem to investigate the cause.
the link is on my drive....do I need to load it to a server for it to work?
here is the code from Dreamweaver
<html xmlns="http://www.w3.org/1999/xhtml" xmlns:v="urn:schemas-microsoft-com:vml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<link href="stylesheetccs.css" rel="stylesheet" type="text/css" />
<script type="text/javascript" src="google_javascript/wagmp_map_1.js">/*wagmp*/</script>
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAvZMU4-DFRYtw1UlTj_zc6hT2yXp_ZAY8_ufC3CFXhHIE1NvwkxQcT1h-VA8wQL5JBdsM5JWeJpukvw">/*wagmp*/</script>
<script type="text/javascript" src="google_javascript/wagmp_map_2.js">/*wagmp*/</script>
<script type="text/javascript" src="google_javascript/wagmp_map_3.js">/*wagmp*/</script>
</head>
<body>
<div id="wagmp_map_3" style="width: 500px; height: 500px;"></div>
<br />
<small><a href="http://maps.google.com/maps?f=d&source=embed&saddr=Interstate+279,+Pittsburgh,+Allegheny,+Pennsylvania&daddr=525+Penn+Ave,+Pittsburgh,+PA+15222&geocode=FY0bagIdkps6-ymTxSum_PQ0iDGk3yoIlGM4eQ%3BFeobaQId3T87-ymv2DR2VvE0iDEGgvhxYSz8dQ&gl=us&hl=en&mra=pe&mrcr=0&sll=40.513076,-80.051253&sspn=0.191323,0.307274&ie=UTF8&ll=40.47997,-80.02602&spn=0.07558,0.0578" style="color:#0000FF;text-align:left"></a></small>
<script type="text/javascript" src="google_javascript/wagmp_maps.js">/*wagmp*/</script>
</body>
</html>
It looks as though you may have some extra code/links left over fro a couple of previous configurations.
Seems to work OK on my local machine if I remove the extra code:
<head>
</head>
<body>
</body>
</html>
assuming that you are working with with wagmp_map_3.
