CMS Intall
Thread began 4/07/2010 3:24 pm by suthany403137 | Last modified 4/08/2010 11:33 am by Jason Byrnes | 954 views | 8 replies |
suthany403137
CMS Intall
Hello
I can not install CMS on my site. Can you help me?
Here's the link: CMS/
Thank you.
shadow329043
You will have to be a bit clearer - what problem are you having?
neilo
Hiya Ny403137,
The error on that page indicates that it can't find a folder and file that it needs to run to continue. It thinks that 'WA_SecurityAssist/Helper_PHP.php' is in a folder one level higher up than it actually is (i.e. - in your site's root directory)
As it seeme that your PowerCMS files and folders are in the correct places (i.e. - all in the 'CMS' directory) then check that the settings in your CMS/WA_Globals/WA_Globals.php file are correct.
They lines you should check are the 'localRoot' and 'remoteRoot' lines which for you should look like this:
$WAGLOBAL_Site_Name = "CMS Admin" ;
$WAGLOBAL_localRoot = "/CMS/ "; //relative path to your PowerCMS files on your local testing server.
$WAGLOBAL_remoteRoot = "/CMS/ "; //relative path to your PowerCMS files on your remote server.
// Admin Settings
$WAGLOBAL_Admin_UserName = "yuoradminusername" ;
$WAGLOBAL_Admin_Password = "youradminpassword" ;
Check that these are correct on the CMS/WA_Globals/WA_Globals.php file that has been uploaded to your site.
Let us know how you get on.
Ny403137
Ny403137. Thanks Neilo for your reply.
$WAGLOBAL_Site_Name = "http://www.marylingerie.com" ;
$WAGLOBAL_localRoot = "/CMS/"; //relative path to your PowerCMS files on your local testing server.
$WAGLOBAL_remoteRoot = "/CMS/"; //relative path to your PowerCMS files on your remote server.
// Admin Settings
$WAGLOBAL_Admin_UserName = "......" ; What is UserName Admin, in Database ?
$WAGLOBAL_Admin_Password = "......" ;
neilo
Hi Ny403137,
Not sure how far you have got with the installation, but the values below (in the WA_Globals.php file):
// Admin Settings
can be what ever you choose for your site's Admin area log-in and password. You can choose and insert these in to the globals file before you carry on with the install procedure, or change them afterwards if you want a different Admin log-in name and/or Password. When you want to change the content on the areas you have set up for content management editing on your site, you will need to log-in to the Admin area to make the changes using those details.
Where are you with the install at the moment? The first step will have been to set up a mySql database and created the tables using the .sql file included in the download (Database/CMS.sql).
That step and all the subsequent steps (or links to the necessary info) are in the 'Getting Started Guide' (although the bit about the setting Globals is referring to outdated documentation and is yet to be updated, but we've sorted that here!).
You may have already sorted all of that, - apologies if so. Let us know if you need any help with any of this.
Ny403137
Hi Neilo (Ny403137)
I already put the Database/CMS.sql in my Database name : marylingerie
admin/
Here is the new message :
You don't have permission to access /CMS/admin/ on this server.
Can I give you my password FTP to looking for ?
$WAGLOBAL_Site_Name = "http://marylingerie.com" ;
$WAGLOBAL_localRoot = "/marylingerie/"; //relative path to your PowerCMS files on your local testing server.
$WAGLOBAL_remoteRoot = "/marylingerie/"; //relative path to your PowerCMS files on your remote server.
// Admin Settings
$WAGLOBAL_Admin_UserName = ".........." ;
$WAGLOBAL_Admin_Password = "........" ;
Waiting for your Help, Thanks !
neilo
Hi there Ny,
There's no need for Password FTPs yet, and if there is, it should go to one of the WebAssist techs. If that time comes, then they will open a ticket so you can exchange details in private.
BUT:
In the meantime, let's look at the error and the messages we get.
The first one (your link, - 'http://www.marylingerie.com/CMS/admin/') which says,
  "Forbidden, You don't have permission to access /CMS/admin/ on this server."
is the response you get from just trying to browse a folder without specifying a particular file, UNLESS that folder contains a designated default type of 'main' page, which is usually called 'index.php', 'index.html' or 'default.html' or default.php etc.That folder should contain your CMS/admin/index.php, which should have opened.
So to test it, I typed in, 'http://www.marylingerie.com/CMS/admin/index.php' (same as your link but with the 'index.php' added), and I get the message,
  "Not Found. The requested URL /CMS/admin/index.php was not found on this server."
As a final test, I looked for another file that I know should be in the CMS/admin folder, 'http://www.marylingerie.com/CMS/admin/help.php' This time, I get a couple of warning/information messages, which both amount to something like,
  "we couldn't open ../Connections/localhost.php which is being requested by line 3 of your CMS/admin/help.php page".
Sorry about the abuse of the quote line, but the meaning is the same, which is that it looked inside your CMS folder for a folder called 'Connections' containing a file called 'localhost.php', and couldn't find it. I couldn't find the Connections folder anywhere on your site. (Root Dir, CMS, Admin).
So I think there is a problem with missing or misplaced files and folders - they may not have uploaded correctly. What I would suggest, is removing all the CMS files and folders from your remote site, and starting from scratch (sorry!).
This time, just upload the entire (preferably freshly) downloaded WebAssist 'CMS102' solution folder after renaming it to just 'CMS' and then upload the whole freshly-named 'CMS' folder 'as-is' to your remote site's root directory. Don't forget to change the WA_Globals.php file to contain details as previously described,
// Admin Settings
Put in a username and password that you will remember during the install process.
Sorry about this, but it will eliminate any doubts about wrong paths, missing files, and wonky structure. It will also probably be quicker to do, than it was to read this.
Post back with how you get on. I may be gone for a bit as it's almost eleven in the morning here and I haven't been to bed yet. I keep odd hours.
AH! Edit: Also, make sure to update the settings in your Connections/localhost.php file with the correct database connection details for your remote database:
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_localhost = "localhost";
$database_localhost = "YourDatabaseName";
$username_localhost = "YourDatabaseUsername";
$password_localhost = "YourDatabaseUserPassword";
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
Cheers
Ny France
Hi Neilo (Ny France)
I still have same problem.
index.php
Warning: mysql_pconnect() [function.mysql-pconnect]: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) in /home/clients/www/marylingerie.com/www/CMS/Connections/localhost.php on line 9
Fatal error: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) in /home/clients/www/marylingerie.com/www/CMS/Connections/localhost.php on line 9
# Type="MYSQL"
# HTTP="true"
$database_localhost = "marylingerie";
$username_localhost = "root";
$password_localhost = "....";
// Admin Settings
$WAGLOBAL_Admin_UserName = "......." ;
$WAGLOBAL_Admin_Password = "...." ;
Cordially
the error:
means that the SQL Server name you provided is not correct.
try changing:
to;
$hostname_localhost = "127.0.0.1";
if that still does not work, you will need to contact your host for the correct MySQL server name to use in the connection file.
Neilo, thanks for your help in getting this far.
