Digital File Pro uploads in Ecart form not working
It seems that I've had this problem before and got it fixed via the old WA forum, so it may be an old issue, hopefully with the same easy fix.
I have a paid registration process for an arts organization. I'm using Ecart 5 to build the form that users, mostly talent agents or agencies, use to register their artists. Part of the registration requires uploading an image. I'm using DFP, the latest version that came bundled with UE4 to handle the uploads and manage the files.
The problem is that an agent can register more than one artist, which appear as items in their cart separately. All of the data except the DFP file input work fine. The file input field only saves the first entry, then all of the rest have the same file name. So, when a user registers more than one artist the image file name remains the same as the first image uploaded.
I seem to remember having to manually modify code to get this to work properly and it was a quick fix. In any case, I need some help on this quickly as the registration period is starting in a few days.
Also, it would be great if Ecart could handle a DFP input field as one of the editable field types. As it stands now DFP and Ecart don't work together without manually editing the code somehow. Please consider this a feature request for the next version of either Ecart or DFP, both great extensions......just need to get together on a few things!
Thanks for your help,
Tony
