decimal points (comma)
Thread began 4/04/2010 4:13 pm by massimo173451 | Last modified 4/07/2010 6:31 pm by Eric Mittman | 1015 views | 5 replies |
massimo173451
Hi there, I need to show the comma (decimal separator) in the cart.php, in the final step now showing the product price value eg. € 13.00 but instead maybe € 13,00. How is possible modify this parameters (using in the Server Behaviours --> eCart Object etc)?
There is a high level setting for this in the cart object. If you click on edit for your current cart object you will see in the general tab the options for currency formatting. You should choose the comma separated example from within here. Let us know if this does not work for you.
massimo173451
Eric, I have already changed, before sent this post, the values (from 10.000,00 to 10,000.00) but the cart show even the price with same value (with dot).
Please post back with a screen shot of what you see in your cart that you would like to change, and also post back with a copy of your WA_eCart folder in a zip archive so that I can examine your cart object.
massimo173451
Eric, I suppose the issue is reproduced when insert a price and weight in the Products_Insert.php (by Admin panel), in the fields price and weight the comma are not accepted (the fields are not formatted, and when insert the price or weight, I get the error in red, and tell me insert the price or weight again). How I can solve this now?
You should be able to get past this by updating the server validations on the page. You can update them with either the Validation Toolkit/CSS Form Builder or you can make the update manually. To update the validations you will edit the server validations and select the number validations that are applied to the price and weight, in here specify the European format rather than the US format.
To update it manually you would go into the code on the page and update the following two lines of code:
$WAFV_Errors .= WAValidateNM(((isset($_POST["ProductPrice"]))?$_POST["ProductPrice"]:"") . "",0,1000000,2,",.",true,4);
$WAFV_Errors .= WAValidateNM(((isset($_POST["ProductWeight"]))?$_POST["ProductWeight"]:"") . "",0,1000000,6,",.",true,5);
You will want to reverse the order of the thousands and decimal separators from this (,.) to this (.,) so they look like this:
$WAFV_Errors .= WAValidateNM(((isset($_POST["ProductPrice"]))?$_POST["ProductPrice"]:"") . "",0,1000000,2,".,",true,4);
$WAFV_Errors .= WAValidateNM(((isset($_POST["ProductWeight"]))?$_POST["ProductWeight"]:"") . "",0,1000000,6,".,",true,5);
