can a select list be used in insert multiple records
Can a multi select list be used when placed in a repeating record for use in an insert multiple records behaviour. All I seem to get is a white page !
Regards
Russell
Regards
Russell
The multiple insert and update server behaviors make use of elements that are within a repeat selection or repeat region area. Using a single multi select list in a form will not allow for multiple records to be inserted.
Making a multiple insert based on a multi select list would require some custom coding to work with an array of values posted from your multi select list, it is not a supported feature of DataAssist.
