Installing Site Assist 3.2.3
Thread began 4/03/2010 3:29 pm by m.korevaar | Last modified 4/05/2010 9:07 am by Jason Byrnes | 1575 views | 2 replies |
m.korevaar
Hello, i am trying to install site assist 3.2.3, but when i want to build a site with it my DW CS4 crashes. I uninstalled SA 3.2.3, and installed SA322, but the same happens again. I looked on the formu, and found an tech bulleting which told me to remove WinCache file, but i could not find that in the right directory. I earlier used SA 3.x.x. and that worked fine.
Please help?
I am using Windows XP V2 all updates installed, DW CS4 registered version
Help,
Martin Korevaar
neilo
Hiya Martin,
The location of the WinFileCache in XP for CS4 is at:
C:\Documents and Settings\User\Application Data\Adobe\Dreamweaver CS4\en_US\Configuration\WinFileCache-3012BA81.dat
The User bit of the path will be your logged in ID.
The alpha-numeric characters between 'WinFileCache-' and '.dat' in the file name will be different every time.
Site Assist 3.x is not compatible with Dreamweaver CS4. to use SiteAssist in Dreamweaver CS4, you will need to purchase an upgrade to SiteAssist Professional:
siteassist/
