Not showing in Dreamweaver
Thread began 4/01/2010 4:23 pm by Mt Shasta Design | Last modified 4/01/2010 5:36 pm by Jimmy Wu | 1354 views | 1 replies |
Mt Shasta Design
Downloaded and added Dreamweaver Tools for Google and it does not show up in Dreamweaver.
When using Pro Maps for Google the map only shows as a placeholder. An API Key was obtained and added so that does not seem to be the issue.
Third try was to embed code from Google Maps (their website) but did not know how to add the API key. So what to do - three attempts and nothing is working.
Dreamweaver Tools for Google used to be in my Dreamweaver and it was the most effective of the three choices. Would like to use it again. It appears in the Extension Manager but I cannot find it in Dreamweaver.
After downloading, the computer was restarted so that is not the issue.
Thanks for whatever help you can give.
Jimmy Wu
If you're using Pro Maps, could you post up a link to a page with the map applied so i can see the behavior?
For Dreamweaver tools for Google, try uninstalling and re-installing to see if they show up. Where are you looking for the access points for the tools?
