PS3 and CSS Menu Writer (?) Errors
I know about going to delete the .dat file, but this is happening entirely too much!
Here's what's caused it the last three times (the last time I did it just to confirm what I was doing to cause the problem): with index.php open, I removed a background color from common.css - outerWrapper #navWrapper #topNavigation.
After closing the dialog box for editing the css, I tried to save the file. I got the error: "A sharing violation occurred while accessing c:\wamp\www\MojoUprisin\css\MFC37f6.tmp
After that happens, not only do I have to go delete the .dat file, but *the common.css file is deleted from my site*. I have to copy it back in from my original Power Store files.
And in case it matters, I have replaced the treexml.xml file with the one you guys posted for us because of the problem with connectivity. (Geesh, gotta hold your mouth just right to use this solution...)
I am carefully editing my Menu, making only 1-2 changes at a time, saving everything, then going back into CSS Menu Writer to try to eliminate all these freak-outs, but my productivity is being dramatically reduced by these constant errors. If I'm doing something wrong, I'll stop - just tell me what it is!
~Fergie
