"Product Added to Cart" message
I want a message to pop up when the product has been added to the cart. Is that possible and how do you do it?
In the add to cart button behavior do not set a redirect for after the item is added in the cart.
After you have added the add to cart behavior, look for the php caode, it will start similar to:
// WA eCart AddToCart
if (isset($_POST["WA_Store_Cart_1_ATC"]) || isset($_POST["WA_Store_Cart_1_ATC_x"])) {
copy that if statement:
<?php if (isset($_POST["WA_Store_Cart_1_ATC"]) || isset($_POST["WA_Store_Cart_1_ATC_x"])) {
and use it around you message:
<?php if (isset($_POST["WA_Store_Cart_1_ATC"]) || isset($_POST["WA_Store_Cart_1_ATC_x"])) { ?>
Item was added to the cart message
<?php } ?>
