500 internal server error with UE3
Thread began 3/31/2010 8:59 am by alan388364 | Last modified 3/31/2010 6:59 pm by Eric Mittman | 551 views | 1 replies |
alan388364
I have created a number of forms in the past that send back correctly with UE3. I have gone through the process again and created an asp page that uses CD0SYS as in my other forms. Now when I uploaded and tried it I got for the first time a timing bar and then the the dreaded "500 internal server error". Where did the bar come from and how do I determne the source of the error message?
Thanks in hope
If you are testing locally and getting the 500 level error it just means that there was an error with the asp server. You will need to go into your IIS control panel and set it to display the full error messages.
This will let you know what the specific error is then you can look into the issue that is reported.
