User Registration Pack
Thread began 3/31/2010 8:57 am by rangerm20c404169 | Last modified 3/31/2010 11:58 am by i.edwards384429 | 563 views | 1 replies |
rangerm20c404169
It has been a long night.
I have Dreamweaver CS4.
I am attempting to install the User Registration Solution Pack.
I have encountered difficulties on applying my template, integrating the pages into my site, and restricting access to a html page.
My site is algebratoday.info
I am using godaddy.com
I need detailed instructions for CS4 to accomplish these tasks.
I have read the Getting Started doc. they are of marginal help.
Thank you.
I can be reached at 773-870-2117.
i.edwards384429
Update
HI
it would help us to have more information as to what your issues are. However I've used the package quite a lot with no problem.
Firstly you literaly copy all the files supplied into the root of your site.
The you need to go into the connections folder and edit localhost.php add the necessary settings for your server - I assume you are building and testing locally.
The second stage is to create a new php file in dreamweaver.
Add in your menu, standard graphics , footer text etc etc.
Then select file.. save as--- template.
You will ne prompted to add editable areas add them to where you want your content to appear. Name the region with something you remember .
the third stage is to open a file from your site in dreamwaver ie userslogon.php
then in the file panel you will see a tab marked Assets,
select panel,
The eighth icon down lists your templates
Highlight your template
Press the Apply button at the bottom.
You will be prompted as to where to put the various content.
Head normaly goes to head
and body content goes to the name you should have remembered.
Your page will now resemble your template.
Do the same for all the other pages.
Seems long winded but it works.
Any problems post back and I'm sure it will all be sorted.
HTH
Ian
