Connecting the database on Godaddy
Thread began 3/30/2010 11:28 pm by admin140217 | Last modified 6/18/2010 10:45 am by Jason Byrnes | 4157 views | 5 replies |
admin140217
Well it seems to be one thing after another lately.
I just uploaded powerCMS to hosting on Godaddy, and set up the database using PHpmyadmin within the hosting account but I'm getting an error when I try to open a page connected to the database.
Here is the error:
Warning: mysql_pconnect() [function.mysql-pconnect]: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/content/64/5760064/html/CMS/Connections/localhost.php on line 9
Fatal error: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) in /home/content/64/5760064/html/CMS/Connections/localhost.php on line 9
I understand that this is probably something to do with the path but I'm not sure what. I was under the impression I wouldn't have to modify any of the files once uploaded.
With that said, the only two files haveing connection data in them are the localhost.php and WA_Globals.php. But I'm not sure of what to change, the connection string to the database, or the local and/or remote naming.
Help would be great!
admin140217
Solved
Okay, I have fixed the issue.
Peter
Would you mind sharing how you resolved. I'm facing my first upload ever to GoDaddy here shortly. Thank you.
the error:
usually occurs as a result of entering the wrong MySQL server name. Your GoDaddy control panel should have the correct MySQL Server name, Username, Password and Database name listed, make sure you use those values from the control panel when running the ePowerCMS installer.
nathan400860
Same Problem:
I am having some trouble. So I have just recently uploaded my e commerce site on my godaddy hosting account. The site uploaded fine except for a few problems. Problem 1: Two product images on the home page did not pop up/ the image was blank. Problem 2. Not all of the thumbnail images SHOW in the shopping cart when I add a product to the cart when it works great in the testing server. Problem 3. I am getting this error when I try to buy a product on the remote server.
"Warning: mysql_pconnect() [function.mysql-pconnect]: Can't connect to local MySQL server through socket '/usr/local/mysql-5.0/data/mysql.sock' (2) in /home/content/s/w/a/swaney777/html/Connections/MyConnection.php on line 9
Fatal error: Can't connect to local MySQL server through socket '/usr/local/mysql-5.0/data/mysql.sock' (2) in /home/content/s/w/a/swaney777/html/Connections/MyConnection.php on line 9"
I'm guessing that the problem is occurring because the check our pages are looking for mysql databass. I have created a mysql databass on my testing server.
If you would like to see these three problems go to www.dvinecigars.com . The domain name is a test domain before I put it on the live server.
Once these three problems are solved the site will work great!
Thanks,
Nate Swan
looks like you posted this twice, see Eric's response in your other thread:
showthread.php?t=13875
