Updating dynamic data with HTML Editor
Thread began 3/30/2010 6:10 pm by tom92909 | Last modified 3/31/2010 11:50 am by tom92909 | 1688 views | 2 replies |
tom92909Beta Tester
I'm having trouble with using HTML Editor v.2.0.0 to pull up a record with an initial value. I can add records with an insert just fine with an INSERT page using full blown HTML Editor v.2.0.0 features, but editing the same file with an UPDATE page, the Editor text box refuses to pull up the record.
Specific Call to edit a specific record example...
eventsupdate.php?rec_id=1027
Works fine if the form field is just a standard TEXTAREA, but once I apply the HTML Editor extension to the same file, I lose the initial value display.
<?php require_once("../HTMLEditor/WARichEditorPHP.php"); ?>
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 CreateRichTextEditor ("comment""/HTMLEditor/""100%""300px""Default""../custom/NEWeventsupdate_comment4.js""{WADAcomments.comment}");
Example:
Any suggestions?
Edit the HTML Editor Instance. Click the lightning bolt next to initial value and select the comment column from the WADAcomments recordset.
tom92909Beta Tester
Ya know... It kept crashing on me yesterday when I tried that, but today it worked.
I have no idea what changed other than a reboot from the overnight Microsoft Security Patch...
$WARichTextEditor_1 CreateRichTextEditor ("comment""/HTMLEditor/""100%""300px""Default""../custom/NEWeventsupdate_comment4.js""".$row_WADAcomments['comment']  ."");
It worked like a champ.
Thanks! :)
