repeat region not working in email
Thread began 3/30/2010 2:41 pm by brian177569 | Last modified 4/01/2010 8:06 pm by Eric Mittman | 915 views | 6 replies |
brian177569
Using PC, WINDOWS XP, Dreamweaver 8, ASP, VB SCRIPT
I am trying to add a repeat region within the body of an email which is using a recordset loop to despatch mail. The repeat region displays all the names of the recipients of the emails i.e.
A copy of this email has been sent to:
user 1
user 2
user 2
etc
If I add the repeat region to Universal Email, the loop will only send an email to the 1st user
but all the repeat region names are displayed.
If I remove the repeat region the mail is sent to all recipients and the recordset loop works OK.
THIS VERSION LOOPS THROUGH THE RECORDSET OK BUT NO REPEAT:
<table width="46%" border="1" cellpadding="2" cellspacing="0" bordercolor="#CCCCCC">
<tr>
<td width="28%" class="style1"><div align="right">enquiry date: </div></td>
<td width="72%" class="style1"><div align="left"><%=(rsAFLASenq.Fields.Item("datinsert").Value)%></div></td>
</tr>
<tr>
<td class="style1"><div align="right">company: </div></td>
<td class="style1"><div align="left"><%=(rsAFLASenq.Fields.Item("strcompany").Value)%></div></td>
</tr>
<tr>
<td class="style1"><div align="right">country:</div></td>
<td class="style1"><div align="left"><%=(rsAFLASenq.Fields.Item("strcountry").Value)%></div></td>
</tr>
<tr>
<td class="style1"><div align="right"></div></td>
<td class="style1"><div align="left"><a href="http://www.agcce.com/emaillogin.asp">Visit Login Page to View Request and update Request Diary </a></div></td>
</tr>
</table>
THIS VERSION PRODUCES AN ERROR, BUT STILL SEND EMAIL AND ADDS THE REPEAT REGION BUT ONLY SENDS TO 1st RECIPIENT:
This email was sent to:
<table width="46%" border="0" cellspacing="0" cellpadding="2">
While ((Repeat1__numRows <> 0) AND (NOT rsUsers.EOF))
<tr>
<td><%=(rsUsers.Fields.Item("strname").Value)%></td>
</tr>
Repeat1__index=Repeat1__index+1
Repeat1__numRows=Repeat1__numRows-1
rsUsers.MoveNext()
Wend
</table><br />
<tr>
<td width="72%" class="style1"><div align="left"><%=(rsPTFEenq.Fields.Item("datinsert").Value)%></div></td>
</tr>
<tr>
<td class="style1"><div align="left"><%=(rsPTFEenq.Fields.Item("strcompany").Value)%></div></td>
</tr>
<tr>
<td class="style1"><div align="left"><%=(rsPTFEenq.Fields.Item("strcountry").Value)%></div></td>
</tr>
<tr>
</tr>
</table>
The tables are used for formatting of the email.
many thanks
Brian Welsh
brian177569
Update
I have tried using:
<wa_recordset_loop name="rsUsers">
<tr>
</tr>
</wa_recordset_loop>
It gives the repeat but only send the 1st recipient mail.
If you are having trouble getting this to work with the same rs for the looping and sending you should try creating a new recordset. This way you could have the looping for the names done with one and the looping for the send done with another.
brian177569
rs looping
I am using 2 recordsets. here is a typical page without the loop in the body and then a snippet with the loop as a repeat region and then another WA loop. I can get around this with adding the recipients manually with a CC, kinda defeats the object of hooking ap a database!
You can see the 2 recordsets below, rsPTFEenq & rsUsers
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<!--#include file="Connections/AsahiGuard.asp" -->
Dim rsPTFEenq__MMColParam
rsPTFEenq__MMColParam = "0"
If (Session("ptfeid") <> "") Then
rsPTFEenq__MMColParam = Session("ptfeid")
End If
Dim rsPTFEenq
Dim rsPTFEenq_numRows
Set rsPTFEenq = Server.CreateObject("ADODB.Recordset")
rsPTFEenq.ActiveConnection = MM_AsahiGuard_STRING
rsPTFEenq.Source = "SELECT * FROM dbo.tblPTFE WHERE intPTFEID = " + Replace(rsPTFEenq__MMColParam, "'", "''") + ""
rsPTFEenq.CursorType = 0
rsPTFEenq.CursorLocation = 2
rsPTFEenq.LockType = 1
rsPTFEenq.Open()
rsPTFEenq_numRows = 0
Dim rsUsers
Dim rsUsers_numRows
Set rsUsers = Server.CreateObject("ADODB.Recordset")
rsUsers.ActiveConnection = MM_AsahiGuard_STRING
rsUsers.Source = "SELECT DISTINCT strUsername FROM dbo.tblAGUsers, dbo.tblAGUserProd, dbo.tblCountryProd WHERE dbo.tblAGUsers.intuserID = dbo.tblAGUserProd.intUserID AND dbo.tblAGUserProd.intProdID = dbo.tblCountryProd.intProdID AND dbo.tblCountryProd.intSubProdID = 1"
rsUsers.CursorType = 0
rsUsers.CursorLocation = 2
rsUsers.LockType = 1
rsUsers.Open()
rsUsers_numRows = 0
<!--#include file="WA_Universal_Email/CDONTS_NewMail_VB.asp" -->
<!--#include file="WA_Universal_Email/MailFormatting_VB.asp" -->
<% If rsPTFEenq.Fields.Item("strlang").Value = "Fre" Then
response.Redirect "http://www.agcce.com/french/PTFEenqemail2.asp"
ElseIf rsPTFEenq.Fields.Item("strlang").Value = "Ital" Then
response.Redirect "http://www.agcce.com/italian/PTFEenqemail2.asp"
ElseIf rsPTFEenq.Fields.Item("strlang").Value = "Ger" Then
response.Redirect "http://www.agcce.com/german/PTFEenqemail2.asp"
Else
function WA_Universal_Email_1_SendMail(RecipientEmail)
dim MailObject, MailAttachments, MailBCC, MailCC, MailTo, MailBodyFormat, MailBody, MailImportance, MailFrom, MailSubject
MailAttachments = ""
MailBCC = ""
MailCC = ""
MailTo = ""
MailBodyFormat = ""
MailBody = ""
MailImportance = ""
MailFrom = "AGCCE PTFE web form submission|WA|ptfe@agcce.com"
MailSubject = "PTFE Information Request "
'Global Variables
gAddBCC = ""
gAddCC = ""
gAddRecipient = ""
gBodyFormat = ""
gSetImportance = ""
set WA_MailObject = WAUE_Definition()
if (RecipientEmail <> "") then
set WA_MailObject = WAUE_AddRecipient(WA_MailObject,RecipientEmail)
MailTo = gAddRecipient
gAddRecipient = ""
else
'To Entries
end if
'Attachment Entries
'BCC Entries
MailBCC = gAddBCC
'CC Entries
MailCC = gAddCC
'Character Set
'Body Format
set WA_MailObject = WAUE_BodyFormat(WA_MailObject,0)
MailBodyFormat = gBodyFormat
'Set Importance
set WA_MailObject = WAUE_SetImportance(WA_MailObject,"3")
MailImportance = gSetImportance
'Start Mail Body
MailBody = MailBody & "" & vbCrlf & ""
MailBody = MailBody & "<p><span class=" & Chr(34) & "style1" & Chr(34) & ">There is a new PTFE Product Request on the<br />" & vbCrlf & ""
MailBody = MailBody & " AGCCE.com website. Click on the link below to go<br />" & vbCrlf & ""
MailBody = MailBody & " to the Login Page. <br />" & vbCrlf & ""
MailBody = MailBody & " <br />" & vbCrlf & ""
MailBody = MailBody & " Please keep the Request Diary up to date with the <br />" & vbCrlf & ""
MailBody = MailBody & " actions you take on all leads as this will be reported <br />" & vbCrlf & ""
MailBody = MailBody & " on a </span><span class=" & Chr(34) & "style1" & Chr(34) & ">Quarterly </span>basis.</p>" & vbCrlf & ""
MailBody = MailBody & "<table width=" & Chr(34) & "46%" & Chr(34) & " border=" & Chr(34) & "1" & Chr(34) & " cellpadding=" & Chr(34) & "2" & Chr(34) & " cellspacing=" & Chr(34) & "0" & Chr(34) & " bordercolor=" & Chr(34) & "#CCCCCC" & Chr(34) & ">" & vbCrlf & ""
MailBody = MailBody & " <tr>" & vbCrlf & ""
MailBody = MailBody & " <td width=" & Chr(34) & "28%" & Chr(34) & " class=" & Chr(34) & "style1" & Chr(34) & "><div align=" & Chr(34) & "right" & Chr(34) & ">enquiry date: </div></td>" & vbCrlf & ""
MailBody = MailBody & " <td width=" & Chr(34) & "72%" & Chr(34) & " class=" & Chr(34) & "style1" & Chr(34) & "><div align=" & Chr(34) & "left" & Chr(34) & ">"
MailBody = MailBody & (rsPTFEenq.Fields.Item("datinsert").Value)
MailBody = MailBody & "</div></td>" & vbCrlf & ""
MailBody = MailBody & " </tr>" & vbCrlf & ""
MailBody = MailBody & " " & vbCrlf & ""
MailBody = MailBody & " <td class=" & Chr(34) & "style1" & Chr(34) & "><div align=" & Chr(34) & "right" & Chr(34) & ">company: </div></td>" & vbCrlf & ""
MailBody = MailBody & " <td class=" & Chr(34) & "style1" & Chr(34) & "><div align=" & Chr(34) & "left" & Chr(34) & ">"
MailBody = MailBody & (rsPTFEenq.Fields.Item("strcompany").Value)
MailBody = MailBody & " <td class=" & Chr(34) & "style1" & Chr(34) & "><div align=" & Chr(34) & "right" & Chr(34) & ">country:</div></td>" & vbCrlf & ""
MailBody = MailBody & (rsPTFEenq.Fields.Item("strcountry").Value)
MailBody = MailBody & " <td class=" & Chr(34) & "style1" & Chr(34) & "><div align=" & Chr(34) & "right" & Chr(34) & "></div></td>" & vbCrlf & ""
MailBody = MailBody & " <td class=" & Chr(34) & "style1" & Chr(34) & "><div align=" & Chr(34) & "left" & Chr(34) & "><a href=" & Chr(34) & "http://www.agcce.com/emaillogin.asp" & Chr(34) & ">Visit Login Page to View Request and update Request Diary </a></div></td>" & vbCrlf & ""
MailBody = MailBody & "</table>"
'End Mail Body
set WA_MailObject = WAUE_SendMail(WA_MailObject,MailAttachments,MailBCC,MailCC,MailTo,MailImportance,MailFrom,MailSubject,MailBody)
set WA_MailObject = nothing
end function
if (("" = "")) then
'WA Universal Email object="CDONTS NewMail"
'Send Loop Once Per Entry
while (NOT rsUsers.EOF)
WA_Universal_Email_1_SendMail("" & cStr(rsUsers.Fields.Item("strUsername").Value) & "")
rsUsers.MoveNext()
wend
if (rsUsers.CursorType > 0) then
rsUsers.MoveFirst
else
rsUsers.Requery
end if
'Send Mail All Entries
if ("thanks.asp"<>"") then
Response.Redirect("thanks.asp")
end if
end if
<% End if %>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>PTFE enquiry email</title>
<style type="text/css">
.style1 { font-family: Verdana, Arial, Helvetica, sans-serif;
font-size: 12px;
</style>
</head>
<body>
<p>&nbsp;</p>
</body>
</html>
rsPTFEenq.Close()
Set rsPTFEenq = Nothing
rsUsers.Close()
Set rsUsers = Nothing
WHAT I AM TRYING TO ADD:
<tr>
</tr>
rsUsers.MoveNext()
Wend
</table><br />
OR:
<tr>
</tr>
Both of the above disable the loop for the send code:
if (("" = "")) then
rsUsers.MoveNext()
wend
rsUsers.MoveFirst
else
rsUsers.Requery
end if
end if
end if
The problem might be present in the code but it would be best for me to test this and see the result that you are getting. If you can post a copy of the db and the files let me know and I can open a ticket so that we can exchange those files in private.
Rite now I'm not sure why it is not working when you have the users repeated like this.
brian177569
Hi Eric,
If I add the recipients manually via cc and add the wa code, do you think that will solve the problem. My client is pretty pi**ed that this is an issue so I need to resolve this quickly or they will baile!
Sorry to be a pain!
Brian
That should be a workaround for this, if you had each user manually listed for the email it should not conflict with the loop that is occurring. I'm not positive this will fix the problem you are experiencing though as I'm not sure why you are having this problem. If you can't get a work around going for it let me know so that I can open up a ticket so info can be exchanged privately.
