PowerGallery Ribbon location: top, right, left
I would like to have an option to put the ribbon of thumbnails at the top, left or right instead of just the bottom.
You should be able to move the thumbnails to the top right now. Just open up the index.php file for the gallery you want to use and move the chunk of code for the thumbnails above the fullsize image. It's possible some other css tweaks will be needed to fully make it work.
I'll add this request to the wishlist for PowerGallery.
-justin
