form appears at the bottom of the page
Thread began 3/29/2010 11:59 am by mrobben375515 | Last modified 4/12/2010 8:27 pm by cliftonr254050 | 1980 views | 6 replies |
mrobben375515
The form on a couple of my pages is at the bottom of the page instead of floating left. the pages are group_registration.php and free_quote.php. I tried to change the form css because I've had this problem a number of times before and I was told to change
form.Sharp_Default fieldset.Sharp_Default {
clear:both;
border-width:0;
to...
/*clear:both;*/
clear:right;
border-width:0;
That has always worked in the past, but this time it didn't. What else could be wrong?
neilo
Hiya,
Make the form float left, - in your FD_NewFromBlank_Default.css stylesheet:
form.NewFromBlank_Default {
float:left;
mrobben375515
awesome! thanks..
neilo
Cool! Glad you sorted it!
cliftonr254050
Cant get form to flote left
Hi Neilo, I am having the same problem as mrobben with my form and I cant find the css file FD_NewFromBlank_Default.css stylesheet: could you direct me to that file.
this is the link to the page contactme.php
neilo
Hiya Clifton,
I find that different forms need slightly different 'tweaks' to show the way you want them to.
The stylesheet for your form is your CSSFormBuilder/FD_Sharp_Default.css file. There may be a quicker and more obvious solution, but for me, what seems to work for your page is to change three bits of the stylesheet. [The changed bits are in blue]:
Near line 96:
form.Sharp_Default ul.formList {
padding:0 0 0 0;
margin:35px 12px 12px -10px;
list-style-type:none;
Near line 135:
form.Sharp_Default label.sublabel {
text-align:right;
width:100px;
float:left;
display:block;
padding-top:2px;
padding-right:5px;
Near line 189:
form.Sharp_Default div.fieldGroup {
display:block;
float:left;
padding-left:8px;
padding-right:8px;
position:relative;
margin:0 0 0 -100px;
See if this works for you, and post back results if it doesn't sit the way you want.
Cheers
cliftonr254050
Neilo you are the man thanks
