Please, I need your help!
Thread began 3/29/2010 11:29 am by Gabriel Tiviroli | Last modified 3/29/2010 6:44 pm by Eric Mittman | 860 views | 3 replies |
Gabriel Tiviroli
Hello friends, I have a big question and I hope I can help, I am a subscriber of WebAssist extensions library and I bought almost all extensions of its authorship. So, I repeat, I hope I can make a contribution to this point because I am no expert in these matters.
The point is that I run a store but that comes with certain peculiarities that make it a much more complex.
It is a store Murals on Tile and Stone. The problem is especially as I have correctly configure the database to eCart works well, because, as you will see in attached schedule, a number of items, such as price, which is divided according to certain issues. If you look at the Excel spreadsheet will better understand what I mean.
Can you tell me as to complete the database? I have downloaded the database you offer free on-site, but would like me to provide guidance on how to adjust it depending on the form that I send, whenever possible of course! from already thank you very much!
Gabriel Tiviroli
Here the Excel file for the help!
Friends, in this post pdf file to go with better understanding, has some parts in Spanish, but do not think is problem.
sample.pdf
Gabriel Tiviroli
Please, answer to me!
Ey! guys please, answer to me! thanks!
You should be able to make use of the regular eCommerce db, but you will also need to customize it a bit. It seems that you will need to ensure that you have all of the various options recorded in tables including the option values and the price for that option.
This is a going to be custom and you will need to determine how your data should relate. The problem is that the table you posted is just tabular data, you will need to ensure that you have all of this information in tables that relate to the items. If you have not seen it already you should take a look at our Database Starter Kit for php, it is a great educational resource on database design and manipulation. Here is a link:
database-for-php/
