error message after insert pg upload
Thread begun 3/28/2010 5:34 pm by muddysmurf | Last modified 4/01/2010 1:58 pm by Jason Byrnes | 2636 views | 5 replies |
muddysmurf
Everything seems to be uploading fine to my database, but once I press, insert, it shows:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\xampp\htdocs\***\Admin\slideadcategories_Insert.php:83) in C:\xampp\htdocs\***\WA_DigitalFilePro\HelperPHP.php on line 70
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\***\Admin\slideadcategories_Insert.php:83) in C:\xampp\htdocs\***\Admin\slideadcategories_Insert.php on line 122
I've looked at this page, 148/ but cannot find any spaces. I've found some, taken them out, but I still get this message.
This is local on my computer. I haven't tried uploading it live, but I've changed the permissions on the folder.
I've attached the insert file. I get the same thing on the update page, once I added the file upload.
I didn't have this problem on the other section that I added the file upload to, but I added a drop down section for the categories.
I've done this a couple of times on the same one and continue with the same error messages, so there is no formatting whatsoever.
the error message is reporting the problem around line 83:
output started at C:\xampp\htdocs\***\Admin\slideadcategories_Insert .php:83
if you look at lines 81 - 83:
<?php?>
the error is being caused by the code at line 82:
<?php?>
muddysmurf
Thanks, That worked.
I saw that in the code, but I wasn't sure why it was in there. I didn't add anything manually, and that <?php?> was in there each time I did the pages.
I will check when I work on my update page in a few minutes to see if it does the same thing (as it did the last couple of times.)
It's like it's a glitch.
**It added the same thing on my update page.
what are the exact steps you are following to reproduce the problem?
muddysmurf
I'm using the DataAssist Wizard to create my Results, Update, Insert, and Delete pages. The only extra thing I am doing to these pages is when It gives me the box to fill out how I want to rename my fields like idcategory_slideshowcat (This is one of my foreign keys) to Category. I then change the "Text" to a "Menu". It then pops up a box where I can pull my Categories table in the database and list the names and not have my client enter, "1", "2" etc.
These work fine with no extra code at this point. I can insert/update without a problem.
I am then adding the file upload to two input fields. (Small and Large) I used these instructions: dfp_da_insert_update_ht.pdf as I usually do.
Once this is completed, I test out the insert and update pages, and that's when the error popped up.
I'm not able to reproduce the problem using those steps.
What is your OS?
What version of DW?
Are you using a template?
