How to modify Nav system
Thread begun 3/27/2010 12:22 pm by ian110201 | Last modified 3/28/2010 4:15 am by ian110201 | 1622 views | 2 replies |
ian110201
Just set up a site through Siteassist Professional.
Then decided I want a different look and feel to my navigation bar. Is there any way to edit it through CSS MenWriter? (I have just purchased the CSS Design Suite.)
OR, should I have set up the navigation system first in CSS MenWriter and then imported it into Siteassist Professional?
Regards
Ian
neilo
Hi Ian,
You should be able to change the style of your SiteAssist menu quite easily. If you can see (in design view) the small javascript symbol next to the menu (see Number 1 in the attached image) then just click on that, and then you can choose to edit the menu from the first button that shows up in the properties inspector/panel (Number 2 in attached image).
If you can't see the little javascript symbol, then go to DreamWeaver Menu > Edit > Preferences > Invisible Elements > and make sure that the checkbox for 'Scripts' has been ticked.
ian110201
Excellent Neilo! Sorted!
