Trouble with css menu writer
Thread began 3/27/2010 12:44 pm by seeblick367554 | Last modified 3/28/2010 7:35 am by seeblick367554 | 738 views | 2 replies |
seeblick367554
My CSS-Mernue-writer application does not work in Dreamweaver CS4.
My computer is an apple Imac with snow-leopard as operating system.
When I try to insert a menu in a dreamweaver HTML-file then I only get problems but no menu.
I can build a new menue as expected but when click done the generator says:
Error generating menu (wa.generate.menu); TypeError MM.WA_createProcessingObject is not a function
When I try to move the WebAssist SiteTools Window there comes an other message:
In file "WA_Site_Tools_Progress": ImportNew is not defined.
So what's wrong??
In the extension manager I deleted all WebAssist PlugIns and installed only the css-menu-writer again but that didn't help at all.
Thanks for your support
Gerd Gerdes
Germany
neilo
Hiya Gerd,
Most often, this is a DreamWeaver glitch that can be solved by deleting your MacFileCache.dat file. (It doesn't mess anything up!). There are some instuctions in this pdf
With Dreamweaver closed, try that first, and see how you get on.
seeblick367554
Hi Neilo,
thanks a lot - that helped!!
Gerd
