data lost after wrong kapcha code entered
Thread began 3/26/2010 12:37 pm by telegen324627 | Last modified 5/12/2010 7:18 am by telegen324627 | 1751 views | 4 replies |
telegen324627
Ok,
So i have been adding fields with dream-weaver to modify the contact form, but the problem that i am having now is that if i enter the wrong kapcha code, or logical question, all data entered is lost on these new fields that i have added. How do i fix this issue?
Thanks in advance
If you are using FormBuilder, there should be values in the bindings for the previously validated entries. Set the values of the form fields to be equal to the validated field value and it will maintain after submission.
(or maybe just add session_start() to the top of the page if it already has the values set properly)
scott351953
Same Problem... Added Fields Clear when CAPTCHA Reloads
I am having the same problem... I added additional fields to the form and made sure to add the validation bindings to the fields initial values. They still clear if the captcha is incorrect. Am I missing something?
scott351953
Need Help.... Please!
I left this message over the weekend... If any one can help me it would be really appreciated.
telegen324627
bind to option
Scott,
Under the assumption that you are using dreamweaver, check out the screenshot where the bind to option is located, change the value as Ray suggested. That fixed my problem
