Css Menu Writer 2.03 and beta
Thread began 3/26/2010 9:40 am by onlyonealibaba | Last modified 3/29/2010 10:09 am by Ray Borduin | 574 views | 3 replies |
onlyonealibaba
I have installed both released and unreleased Versions of css menu writer without any errors during installation. But however once completing the WYSIWYG and hitting finish button in both versions i get a new window "Webassist site Tools" and "Site Tools". these windows sit idle whether i push go or not! i have deleted the DreamWeaver Cache file from the recommend forms. However i have also installed site assist which Gens the menu and allows me to see the edit buttons but will not allow me to regen the updates that i have made. i am running vista and cs3 what do i do next
It sounds like it could be a problem with your dreamweaver installation. Do you have eCart or site import? It sounds like dreamweaver floating windows might not work properly and both of those products use floating windows, which is why I ask. If they also didn't work similarly it would support my guess.
What version of Dreamweaver are you using? Did you install from adobe downloads or did you install from a disk or other location? It might require a reinstallation of Dreamweaver to fix if I am correct.
onlyonealibaba
Shall try
i am useing Cs3 Though i have used the floating windows before and thus far it has worked... i shall try reinstalling dreamweaver and see if that helps.
-oh yeah i do have ecart installed
-i have been able to go through your SiteAssist Gen code and change what i want...
If you still have issues, let us know and we can set up a support incident to investigate and debug the cause directly.
