SA Pro won't install
Thread began 3/25/2010 5:29 pm by Peter | Last modified 3/29/2010 7:48 am by Ray Borduin | 1856 views | 9 replies |
Peter
I have tried repeatedly to install the latest ver. 1.0.7 but for some reason it will not complete the install. It acts like it's installing the extension in Adobe Extension Manager (CS4) but then isn't there after it appears to be finished. I've tried shutting down DW and EM several times and re-starting. I've deleted the win cache file. None of these solves the problem and now I'm also getting several error messages when I start DW (attached). Please advise.
p.s. I tried opening DW again and received an entirely new error message:
"The following translators were not loaded due to errors: WA_forms.htm: Has configuration information that is invalid"
It looks like you may have uninstalled an old version after installing the new one, or it wasn't installed properly.
I'd completely remove and reinstall the extension, then clear the winfilecache.dat file and it should start working for you.
Please post back if that doesn't work and we can work with you directly to diagnose the problem.
Peter
I uninstalled the older version before trying to install the latest. I thought that was the recommended procedure. Should I try re-installing the older one and try to do something from there?
No that should have worked. It is behaving as if you uninstalled the older version AFTER installing the new one.
Maybe try uninstalling and reinstalling the new one. I'll create a support incident in the meantime so we can call you and investigate further.
Peter
OK. There really nothing to uninstall, which is the problem. Nothing showing up in the extension manager. My hours probably won't match up with WA's support hours for a call. Will likely need to resolve via a tech support incident.
I think you may need to delete your configuration folder and reinstall the extensions you want to use.
first close Dreamweaver, then
In explorer type: %appdata%
Then browse to the dreamweaver version you are using and find the configuration folder under it.... rename it to configuration_old
Now open extension manager and remove all the extensions listed, then install any that you want. Then let me know if you have any problems from there and we can get on the phone to connect with you.
Peter
Ugh I followed your instructions, then tried re-installing SA Pro 1.0.7 first and same result. Appears to be installing but nothing showing in extension manager.
I have never heard of that... Update your open support incident with contact information and we can review it over the phone while screen sharing.
Unless you are overlooking something it really sounds like it could be a problem with your Dreamweaver or extension manager installation and it may requiring reinstalling those adobe tools to get working.
Since it is late in the week we probably won't be able to call you until monday, so you might want to try a Dreamweaver reinstall over the weekend.
Peter
I completely uninstalled DW (ugh again), reinstalled, tried reinstalling the extension and same result. I downloaded the extension again from the WA site and tried installing that with same result. I decided I would try to re-install the earlier version of SA pro that I had which was 1.0.4. It installed just fine. I tried to install 1.0.7 over the earlier version, no change... it's still 1.0.4. Seems like an extension problem, doesn't it?
postscript: One additional observation that I don't know if it adds much. When the 1.0.7 appears to be installing, no boxes ever come up like the one for accepting the license agreement or asking if I want to do "Yes (or No) to all"
I'll open a support incident so that we can look into this issue with you directly. Thank you for your patience. Please update the support incident in your support history at the webassist web site. Include a phone number and a good time to contact you and we can try to debug this issue further over the phone.
