Sculptor issue with CS4 in XP
I am getting an error message when trying to open a new sculptor 3 page. then the sculptor box is blank grey. I took a screenshot of the error message...
Have you tried deleting your cache file with the steps listed in this document?
technote...ion_issues.pdf
Please give this a try, if you continue to have problems there might be an issue with your configuration folder. If this is the case you should be able to get past the issue by renaming your configuration folder, here is a link to instructions on this:
show...93&postcount=2
I am having the same problem with cs4 & css sculptor 3 as jb_bell60646 above could you please re post the second link for me I am getting a 404 – not found when I click link.
Sorry about the broken link:
