Do you need API key for every sub domain?
Thread began 3/24/2010 11:41 am by mr hankey | Last modified 4/16/2010 1:50 pm by Jimmy Wu | 1886 views | 5 replies |
mr hankey
hi,
my website will have about 25 sub domains which will all have the same database but their own.
do i need an API key for every sub domain?
also is it possible to sue pro maps to show all clients on a map to see where the majority of them are from?
many thanks
Jimmy Wu
If its in a subdirectory of the domain, then you shouldn't need to request a new API key.
To map all the client locations on one map, the easiest way to do this would be to store the different parts of the address (street, state, zip, etc) in a database, then add a recordset to the page that gets the different address columns. In the pro maps interface, on step 2, you can click on the show multiple checkbox and bind the values to the different columns in the recordset.
mr hankey
thanks jimmy, so if i use the one api key, other companies that have seperate sub domains should not see anyone elses maps or data etc?
many thanks
Jimmy Wu
No, the code for each of the maps is created differently, so each time you apply a map, it will create a different set of code that will store the mapped points for you.
mr hankey
thanks jimmy
Jimmy Wu
No problem. If you run into any additional issues, feel free to open a new thread.
