Simple Vertical Menu - removing right arrows when there are no sub-menus present
Thread began 3/22/2010 1:47 pm by sandy170299 | Last modified 3/22/2010 3:34 pm by sandy170299 | 1442 views | 4 replies |
sandy170299
I am using the Simple Vertical menu in Granite Pine and am trying to figure out a way to remove the right arrows when there are no sub-menus.
Like this example: pipes.htm
The right arrows only show when there is content to be displayed. How can I achieve this with CSS Menu Writer?
Thanks!
Jimmy Wu
Unfortunately, the design just has arrows as part of the image. There isn't a way to display a different image if there are submenus from the one that doesn't have submenus, unless you modify the code after the menu is generated to reference a different image.
sandy170299
Do you think you'll ever be adding this feature - like the Project Seven menus, where the current menu is "marked" if there are sub-menus to that menu?
Jimmy Wu
It may be added in the future. The best way to suggest something like this is to post in the Wishlist forum asking for it.
sandy170299
I will - I want this feature :)
