Update Multiple Records Fix available when?
Thread began 3/20/2010 5:08 am by christian397409 | Last modified 3/20/2010 7:19 am by Ray Borduin | 850 views | 1 replies |
christian397409
Hi.
I've experienced some issues with the WA Update Multiple Record SB (WA UMRSB) and I realize there are several other developers that have done the same.
It worked fine for me when I decided to not use a table as the repeating region but used a set of fields instead. Then it worked perfectly except for a SpryValidationTextfield I had in the set, which repeated but dropped its validation features completely in all rows except the first one. (Honestly, I have not thoroughly checked if this Spry issue is a WA UMRSB issue or a DW issue, but my gut feeling is that the Spry issue is connected to the WA UMRSB.)
So, my questions are as follows:
1) When will this fix be available so that also tables (or any layout element) can be used for WA UMRSB?
2) Will the WA UMRSB also manage Spryvalidation for each multiple input?
Many thanks in advance.
BR / Christian
1) Do you have a sample file where you have tried. It should work, so if you have a sample file you have tried and is not working we can take a look at it and see what is wrong. If we find a problem then we can fix it, but as far as I know it really should work.
2) Mulitple updates existed before Spry. Spry validation won't work in a repeat region with or without multiple updates or any other extensions installed. This isn't a bug with multiple updates it is a limitation of spry. We could come out with an update, feature, or new product to make spry work with repeat regions, but it still wouldn't really have anything to do with multiple updates.
