no results
I am not getting any results returned on my events search.
Can you explain a little about how you have the search setup and the results that you are expecting to get when certain values are searched on, this would help us better understand the problem. Also, any info about the table that is used in the search might help as well, if you can post a copy of the exported table this would be best.
