repeat region show records
Thread began 3/18/2010 5:34 am by randyw2394710 | Last modified 3/18/2010 9:06 am by Eric Mittman | 912 views | 1 replies |
randyw2394710
i have an index page outside of power cms, which has a repeat region to show records, which which it does. I have a repeat section which is only supposed to have 3 records at atime. It shows all the records I have attached the index page.
index.zip
The repeat region looks to be setup correctly to limit the query to three records at a time. Would it be possible for you to post a export of this table from your db? This would help to determine why you are getting the result you are seeing now.
