Upload an image before the submitting of the form
I wonder how I can upload the image using digital file pro, before actually the submit button is pressed. I am using the image with an insert record form.
You either need to upload the image before you are sent to this form page or you can have the upload occur after the form is submitted but before the record is inserted.
It is not possible with DataAssist to have the file upload before the form is submitted. Are you wanting to have your insert occur only after the file has been successfully uploaded? If so you can apply the DFP upload server behavior then in your DataAssist insert server behavior you can update the trigger to be files successfully uploaded.
