A suggestion for the team
Thread begun 3/17/2010 4:34 am by msummers194171 | Last modified 3/17/2010 12:59 pm by Justin Nemeth | 1311 views | 2 replies |
msummers194171
In the WAGlobals configuration file, there should be a way to specify the table name or perhaps a prefix to use for the table name (in the same way that WordPress allows). This would facilitate installing the suite into a database that may already have a table named "users".
Jimmy Wu
Thank you for your suggestion. I have moved your thread to the Wishlist forum, since you are making a feature request. The product development team will take a look at your suggestion and determine if it will be added in a future release.
Justin Nemeth
With the recent releases of PowerGallery and PowerStore, those solution prefix the tables to help make them more unique. So PowerStore 3 for instance uses ps3_users instead of users. So that doesn't fully address your issue, but the recent and future solution packs will have a prefix that effectively will solve your issue.
-justin
