adding fields to the CMS pages
Thread began 3/16/2010 9:26 am by muddysmurf | Last modified 3/16/2010 2:25 pm by Dani Chankhour | 486 views | 1 replies |
I've used DataAssist to create my content management system. My client has decided to add a row to one of my tables to be able to sort by this column. The CMS is already built (generated by DataAssist).
Last time I looked, once I added a row/column to the table, the backend pages doesn't want to update and I would have to start from scratch to add the Update/Delete/Insert pages.
What is the easiest way to add this column into these pages?
Dani Chankhour
After you add the column to your database, you will need to update the insert/delete/ and update page to have an additional form field for that column and then you will need to update the insert and update server behavior to bind the value of the new form field.
