Why is it that a user that registers can access the Admin section?
Thread began 3/15/2010 8:17 pm by rdream188601 | Last modified 3/15/2010 9:18 pm by Jason Byrnes | 529 views | 2 replies |
rdream188601
Jimmy Wu
This shouldn't be the case. The user should have to be edited by an admin to admin status before being able to access the admin pages. Do you have a url where I can see this behavior? Also, you should check your ps3_users table and check the UserGroupID column to make sure that newly registered users have the UserGroupID set to 1. If they are all set to 2, then they are all marked as admins.
it is possible to be logged in with the administrator user name and logged in with a regular user name at the same time.
There are two different session variables that are evaluated for the admin section and the store section.
make sure to log out of the admin section before logging into the store section.
