Making it easier to setup PowerStore Product Catalog
Thread began 3/15/2010 1:40 pm by markymark44 | Last modified 3/15/2010 4:47 pm by Jimmy Wu | 510 views | 1 replies |
markymark44
I have several PowerStore websites to setup for numerous items
with multiple options....
Is there a way to copy or step and repeat the conditions or options
as a template to make it easier?....instead of spending 30 minutes setting
up each particular item? It would be such a time saver if possible/
any input would be appreciated-
Jimmy Wu
Its possible, but it may not necessarily save time. If you're setting up different products with multiple different options that have different settings, you'd have to manually insert all these different values into the database in any case. If you're inserting simple options, where the cost, description, etc are the same for each of the options, it should not take you that long to insert a product using the admin interface.
