Database Updating Problem - ASP JavaScript
Thread began 3/15/2010 6:59 am by arodriguez394222 | Last modified 3/15/2010 2:04 pm by Jason Byrnes | 1684 views | 3 replies |
arodriguez394222
I'm working with ecart 4 ASP JavaScript, and I recently added new information to the database (new categories to be specific).
I can see the changes when I load the asp pages using my local testing server, but when I load the same page on the web I'm not able to see the changes made to the database.
I have uploaded to the server on my Host: the database itself, connection files, asp pages modified.
Here it's the link:
store_v1.asp
I should see 20 categories, instead I'm seeing only 10.
Thanks,
Rafael Ordaz
double check that the local copy of the database has been properly uploaded to the server.
I would suspect that the databaser on the server does not contain the same data as the one being used locally.
arodriguez394222
You were right, I had two database directories and I was writing to the wrong one...
Thanks a lot!
no worries.
