Content not showing on website
Thread began 3/15/2010 8:56 am by info296210 | Last modified 3/17/2010 7:58 pm by Jimmy Wu | 1133 views | 7 replies |
info296210
Hi
I've loaded the CMS. Gone through to insert new content and added the developers code. Howeveer when I look at the development site I'm useing on the internet I get the following message.
Fatal error: Call to undefined function: wa_getcmscontent() in /homepages/19/d315727924/htdocs/WebsiteDNA/dev/auguries/TMPac92szbqa2.php on line 902
The hedaer and menu are showing fine so I presume the conncetion with the dtatabase is fine. Have I configured the content connection wrongly?
Any help really appreciated. Thanks Greg
Jimmy Wu
On the page that has the error, is there an include for the WA_CMS.php file located in the WA_CMS directory? Also make sure that the WA_CMS.php file is indeed uploaded to the WA_CMS directory. This is the file that defines the wa_getcmscontent function that is causing the error.
info296210
Thanks Jimmy
The only code I added to the web page was the code from the Web Developer section when I added the content created in the CMS. This code was:
include('/homepages/19/d315727924/htdocs/WebsiteDNA/dev/auguries/cms/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_localhost, $localhost, 'index.php' , 'center');
There is no include for WA_CMS.php. What coding should I add to the page and where should I include it? Many thanks Greg
Jimmy Wu
You would want to add this at or near the top of the page:
<?php require_once( "../WA_CMS/WA_CMS.php" ); ?>
Depending on where the file is located in respect to the WA_CMS directory, you may have to change the path though.
info296210
Hi Jimmy
Appreciate your help. I put in the extra include as suggested but still get an error showing as below:
Fatal error</b>: main() [<a href='plugins/function.require'>function.require</a>]: Failed opening required '../WA_CMS/WA_CMS.php' (include_path='.:/usr/lib/php') in <b>/homepages/19/d315727924/htdocs/WebsiteDNA/dev/auguries/index.php</b> on line <b>14</b><br />
I've still got the background colour image through the style.css folder but now lost the image and menu bar. Any ideas on how I can resolve the issue? Can be seen at index.php
Many thanks
Greg
neilo
Hiya info,
Try changing:
<?php require_once( "cms/WA_CMS/WA_CMS.php" ); ?>
info296210
All sorted. Great Forum
Many thanks neilo - really appreciate the help.
Greg
Jimmy Wu
Great to hear it, if you run into any additional issues, feel free to open a new thread.
