Header already sent error.
Thread begun 3/12/2010 8:55 pm by fmcmaye260919 | Last modified 3/14/2010 2:27 pm by Office Guy-172461 | 2939 views | 5 replies |
fmcmaye260919
I keep getting this error from the Test Server (localhost/website) on every link I click:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at C:\xampp\htdocs\africabizconnect\sellingleads.php:3) in C:\xampp\htdocs\africabizconnect\WA_SecurityAssist\Helper_PHP.php on line 9
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\xampp\htdocs\africabizconnect\sellingleads.php:3) in C:\xampp\htdocs\africabizconnect\WA_SecurityAssist\Helper_PHP.php on line 9
But it is exactly the same website on my remote server, and I don't get this error from my remote (www.website.com).
I have looked at the code a hundred times; eliminated all white spaces, etc.
I need help!
Office Guy-172461
I suspect you are using a Linux remote server and a Windows testing server.
Check for cr/ln at the end of the files.
fmcmaye260919
Yes, it's linux remote, and Windows test server, but I have been using the same setup for three years and never had this problem. The only difference now is that I am using xampp server instead of one I set up myself, and I have implemented the Web Assist Contact Form Solution.
Also, I downloaded the site from my Linux server that is live. It works just fine there. Now I have over two thousand pages on this site, and every single page now comes up with this warning. Do I have to go into every single page and eliminate extra lines? That's what seems to fix it.
Oh, also, I have just updated all the Web Assist Extensions to the latest, and I am running on Window 7....my latest update to the Linux server was from an XP machine that crashed, so I lost the original site that I uploaded to the Linux server, that is still working.
Any idea what's going on?
Office Guy-172461
Have a look here:
flip/
The difference is that before you copied from Windows to Linux (which made the conversion) and now from Linux to Windows (which didn't make the conversion).
fmcmaye260919
Thank you. I understand now. Still I don't know how to fix it. Should I download the flip utility and run it? Which one? The Linux one or the Window one? Is there a step by step instruction on how to go about doing this? Also, I didn't see one for Windows 7; I only see one for XP.
Thanks again for your continued support.
Office Guy-172461
The Windows XP version should work. I don't do Windows 7 so I can't tell for sure.
Create a working folder and download the flip program into the new folder. Copy a few files from you site into this directory for testing.
Go to the command prompt (dos) and type this command (assuming you have a file called test.php):
flip -t test.php
This will tell you what the current file type is.
To change it to Unix type:
flip - u test.php
To change it to DOS type:
flip - d test.php
Unfortunately it does not understand wild cards, so you will have to repeat for each file. Use the up arrow to bring back the last command entered and backspace over the last file name and use the tab key to cycle through file names.
If you have a lot of files you might want to do them in batches, moving the finished ones to a different folder, and copying news ones in for processing.
