installation PS3 didnt work
What should I do if this errors occured?
what is the address in the address bar of your browser?
Is this on your local computer or on a remote server?
It looks like you are either accessing the installation files locally through the file system, not through a local web server.
The installation script is a php application. It must b run on a web server that supports PHP processing. This could be a local server you have configured using MAMP or XAMPP, or your remote web server.
It's ok the problem has been solved by my hosting provider. Thanks
