Unable to embed PowerGallery code in PHP Page
Thread began 3/11/2010 11:39 pm by markymark44 | Last modified 3/25/2010 5:17 pm by grgsr | 1113 views | 5 replies |
markymark44
I have installed PowerGallery 1.0 and 1.1 numerous times with no problems...added and manipulated images/no problems..but I can't seem to embed the code properly to display in a PHP page. My knowledge of PHP is limited, would someone mind walking a newbie through the procedure? I would be most grateful-thanks
on the add to site page, copy the php code that is given, example:
$pg_id
'1'
$pg_theme 'dark'
include(
'/Applications/MAMP/htdocs/pg/galleries/ribbon_fullsize/index.php');
Open the page you wish to display the gallery. In design view, place your cursor where the gallery should display, the go to code view and paste the php code from the add to site page.
markymark44
Thanks so much! worked perfectly..
M
grgsr
Changing page format from htm to php
I had tried for a while to get the gallery to show after embedding the code in a htm page and could not get it to work. Found this post and figured out why. I then saved the page as a php page and it worked.
I had used SiteAssist Pro to create the site and the default page format was htm. Is there a way within SiteAsssit to create a php site?
I ask because I will end up with many pages of htm which could be deleted after inserting the php code for Power Gallery. If I do delete them because I saved them in php after embedding the code for Power Gallery I would have to manually update all the links.....
Pending on the size of the store and the number of pages there will be a lot of unused pages once they are saved as php.
grgsr
Justin Nemeth
If you change your Dreamweaver site settings to indicate a PHP testing server, SiteAssist pro will output files with a .php extension.
grgsr
Thank you Justin
Hi Justin:
I did not set up those priameters up front. I was working along and using Xammp and never gave it a second thought until I started with Power Gallery.
Unfortunately I am starting from scratch. I will try to keep this in mind when developing additional sites.
Thanks,
grgsr
